RE: OFFICIAL Team Losi Micro-T thread !!!!!!!!!!!!!!!!!!!!!!!!!!!!
ILoveMinis, let us know how that works out. The Azzar antennas would be perfect for this set up.
All good advice from ClutchBob...Vtecguy, remember too that a 200mah 3.7v parallel pack will only peak at around 4.2 volts. Under load you'll be looking at ~3.9volts at best. You'll see much lower speeds with the micro at that voltage. I have read that this has been done successfully if you switch to the largest pinion, but speeds will still be lower. I think the person that tried it was looking for longer run times and quicker accelleration on a tight course. I think this would be the only application where a 3.7v parallel pack would be handy.
