RCU Forums - View Single Post - 91 surpass II lsn
Old 02-05-2007 | 12:48 PM
Bax
Default RE: 91 surpass II lsn
You'll have to remove the carburetor, disassemble the carb, and then install the idle adjust by threading it back in from the inside of the carburetor. Use a very small screwdriver in the slot. A small screwdriver will fit inside the hole. Just be careful to not damage the threads.
