RCU Forums - View Single Post - BME 100: Shake maker
Old 02-06-2003 | 07:22 PM
captinjohn
Default checking for bent crank
RCIGN: If a person set-up a dial indicator at the very tip or near tip of prop.... then turn prop 180 degrees to see the position of other tip...would that be another way to varify this problem? Could try it with a couple of different props and if the tips did not have about the same reading...something is bent or ???? Thanks Captinjohn
