Liquid cooled touring car
Just ordered one of these from Ebay. Does someone have this ? How good is it ? I hope it works good , it sure adds that special edge on a TC .
What do you thinck ?
Quote from the seller:
Over the last few years battery technology really moved forwards and provided R/C car racing with reliable cells with great performance. The low internal resistance and high capacity of today's batteries has cured the longstanding problems of lack lustre performance and poor duration. But it has brought us a new and irritating problem, HEAT!
Heat is the enemy of high performance electric motors causing constant rebuilds and higher internal resistance which slows Modified and Stock Racing motors alike.
The new Multi Patented TCS has been meticulously developed over the last 12 months to address the "Heat problem" and promises new levels of performance and reliability which can be fitted to your existing car.
With possible changes to racing regulations in mind The TCS has been developed using 4 and 5 cell configurations too, with equally stunning results.
A tiny Micropump
circulates a non-conductive liquid through the system. The fluid passes through a thin plate which is sandwiched between your motor and chassis where your motor's excess heat is extracted into the coolant. Forced by the pump the coolant continues to the cooling radiator which efficiently releases all of the excess heat, into the passing airstream.
You save money too, because overheating destroys your motor magnets, brushes and commutator, meaning constant rebuilding and sometimes blown motors and speedos.
EFFICIENT? - oh yes!
The specially developed TCS pump uses less than 0.5 watt, whereas a typical twin fan setup uses over 2.5 watts.
