RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 02-05-2007 | 07:37 PM
  #129
PilotTiger
Default RE: New CDI - opensource project JMJ and Bigboat
Bigboat, I did that. I had set it to the 16f628a and to 4mhz. I had saved it as CDI Timer and still, the error said that there is a problem. In the editor window it says in a new tab cpp.err and in the window - c:0: warning: Unknown encoding: 1033. In the error window it says under line/column - 1:2, under message text - function main not defined.
Also, did anybody build the RCD Programmer that is linked from bigboat's page? I did it and it looks from the component's side identical, yet when i connect it the ground plane is positive and the plus part is negative. Should I program something on the computer to change it? I checked over and over and it is not a mistake on the board or my mesuring, that's how it comes out of my computer. Pin 3 Neg. Pin 5 Pos. Just the oposit of the plan.
Yoram
