RCU Forums - View Single Post - What can cause the glow plug to fail
Old 02-05-2007 | 09:48 PM
downunder's Avatar
downunder
Default RE: What can cause the glow plug to fail
The plugs are blowing the insulating seal which is fairly rare nowadays but still not unknown. Once the seal goes the engine loses compression which can make them hard to start and then they run poorly as well. It's not a fault of the engine. Lean running will usually just blow the coil.
