RE: Antenna inside fuselage?
What is the length of the revolution antenna? You might consider mounting it inside along the curve of the plastic canopy, angled back from the instrument panel. Would be more 'vertical' than the lower front fuse, perhaps further from carbon fiber reinforcement, and not point at you when the aircraft flys directly towards the transmitter.
