ORIGINAL: Bigboat
Somewhere into the program, you make changes and I don't mean the tabel.
It can be a { or '
Copy / paste the original sourcecode into micro-C and try again.
Copy and paste is what I did. I didn't change anything since I wouldn't know what I'm doing, so no use trying.
BTW, I have a few RDC-programmers and all work fine.
Check the PCB, maybe you make a mistake.......??
My PCB is identical. The problem is, as I stated, that the output from my computer to the RCD Board, when I measure on the cable, is that the plus and minus are differnt than on the plan. Pin 3 is negative on my cable and it should be positive according to the plan.
I hate it when these things happened. I think I'm going to go and jump out of the window. Never mind that I live on the ground floor.
Yoram.
BTW, I could try changing the PCB layout to reflect what comes out of the connection cable but I wonder what about the other pins. I can check plus and minus but wouldn't have a clue about the correctnes of the other pins. I guess I'll just have to try.
