RE: Ryobi 31cc engine setup
I ended up putting the primer bulb on the carb and have never used JB weld on the carb so I dont think thats the case. Im going to try and clean out the high end needle like you said and if Im still having problems, Im going to switch over to the Zama I have off of the other Ryobi. Hopefully my Walbro will be fine and only need a bit of cleaning, and I will go back around and make sure all my fittings are sealed correctly. I put some nicrome wire around every fitting today, but I will recheck all of that.....Thanks for the help!
