RE: tips for going vertical
May I also add that a plane that balanced LATERALLY will climb a vertical upline straighter than an unbalanced plane. Lateral balance is achieved by holding the plane in a way that you can see which side is heavy. Attach weights on the wingtips, on the CG to achieve lateral balance.
