RCU Forums - View Single Post - Falcon 3D doesn't work in the cold?
Old 02-07-2007 | 07:14 PM
devmode's Avatar
devmode
Default RE: Falcon 3D doesn't work in the cold?
I've actually had problems in the cold too. The gyro won't init - seems like it is in conjunction with the tail rotor. I tried sitting it outside to adjust and just taking it immediately outside. Happens in both cases. Some times it is fine, some times it isn't.
I'm going to try a different gyro to see if that helps ... along with piecing the bird back together after the last "flight".......
