RE: Nitro Models Extra 330 90 - 63"
I am in the build process also. If it flies as good as it looks ( quality and appearance ) I will be very happy. Mine did not come with a bellcrank for the elevator. The directions are very vaque but it appears from the hardware provided that the intent is to run a single control rod from the elevator servo to two rods via a wood dowel. Then both those control rods out to each elevator half. Am I correct in this? I am going to run an SK .80 it a 13 x 6 prop. You guys think it will hover with this setup?
