4ch controller setup for 3Dplane?
how do you set up a controller for a 3D plane? wich stick should go up an down of left or right, to controll the different rudders on the plane? eks, if you press the left stick on the controller to the right, should the plane tilt to the right and go upside down. . or should the nose of the plane turn right then? I've just bought a Katana EP, but I haven't tried it yet.
