RCU Forums - View Single Post - Is PCM necessary to fly a converted gasser with?
Old 02-08-2007 | 06:50 PM
wildchild45177's Avatar
wildchild45177
Default RE: Is PCM necessary to fly a converted gasser with?
A proper setup will be fine on either FM or PCM. On FM if you have any glitches you will see them but maintain control. On PCM if you have any glitches you may not see them, but this can be a bad thing. If they put your PCM system in lockout you have no control. I would suggest that you setup with FM, make sure there are no glitches, and then if you feel the need, go PCM. Just remember PCM does not stop glitches, it only covers them up, and at a certain level of them, goes into lockout. Personally I use FM so I know if it happens, but a good setup will not normally glitch.
Bob
