RCU Forums - View Single Post - Make your 2$ Landing Gear
Old 02-08-2007 | 08:15 PM
Fesfly
Default RE: Make your 2$ Landing Gear
The problem with using foam attached to the motors is the heat so it should be heat resistant foam or it won't last long. You don't want to cover any motor vent holes. The nice thing about the solution presented here is you save your motor mounts which usually break when used as a support for landing. And when one of those goes, heat up the soldering iron, pain in the butt.
