I will post some pix tomorrow because tonight I am waiting for the 30 minute epoxy to set up. I had a hard time getting the stabs adjusted as per the plans. It seems too loose so I decided to do things the old way. I am doing one stab at a time and setting it at zero with respect to the wing. I added some milled fiberglass and glued the stab in place. Aluminum tubes and all. Tomorrow morning I'll do the other one. That way I know it wont come loose and flutter. : AKA lost plane etc. Adjustable stabs are nice if the engineering is right. I don't think their system is that sturdy. So far I like the plane and will weigh it when I finish. They have stretched the fuse and added more rudder so it should be a good plane for what it was designed for. I've got a well broken in OS 91 four stroke ( SPA Special) Should be a perfect choice.
