RCU Forums - View Single Post - Power Panel and Battery Leads
Old 02-08-2007 | 09:49 PM
alan0899
Default RE: Power Panel and Battery Leads
G'day Dick, me ole mate,
Sorry Dick, but car chargers, for your typical lead acid battery, will cook your typical gel cell, they charge too fast, usually at about 4 amps, that will cause gasses to accumulate in the battery and they can't vent the gas, after a while you will see the sides of the battery swelled out, & that is the end of your gell cell. That is why you should remove the caps from a lead acid battery when charging.
You need to charge em at about 500 to 800 Ma depending on the size of the gell cell. Slow is better. As Rcfury said, a Battery tender Jr is the ideal charger for your gell cells, I use one for my flight box & my Harley battery.
Hey Dick,
I'm working on my Yak 54, as I type, I will be putting an AR7000 RX in it, Spektrum for ever!!!!!!!!
