RE: Zeque Build Glow Powered...
Doc's (a very funny guy...especially with Frank D.) post regarding servos in the tail.
The weights I mentioned a few posts "up" pretty well define the components...basically the same total weight. The challenge is "where" the weight is located. I will be using the same Hatori header/muffler combination and based on the layout of Mr. Suzuki's model with the battery and rx in the fuse behind the tank. I assume you will be tail heavy. Some pilots like how that flies and feels. Personally, I do not. The plane can handle a big a#$%& battery in the front, but you probably did not invest in THIS model to have to resort to that requirement...
Rusty Dose
Team Futaba
Team YS Performance
