RCU Forums - View Single Post - PULL-PULL conversion on Sig Something Extra
Old 02-09-2007 | 07:05 AM
CGRetired's Avatar
CGRetired
Default RE: PULL-PULL conversion on Sig Something Extra
That looks pretty slick. I see another servo there.. Assume that's your throttle?
I was going to put the throttle closer to the front using a small servo (Hitec HS55 or Airtronics 94051Z MicroLite Servo. Don't need a lot of torque to operate a throttle, and it will fit pretty much anywhere forward of the servo tray.
I was also thinking of the elevator on pull-pull and you just made up my mind for that.
Did you consider mounting the servo's directly behind one another with the more forward one elevated by 1/4 inch blocks to put it above enough to clear? I know.. do the math... the angle does not put in differential.. or very much of it when mounted slightly off set.
Anyway, nice looking setup. Thanks for that.
DS.
