RCU Forums - View Single Post - Official HPI MT2 Thread
Old 02-09-2007 | 02:25 PM
  #13109
nickrummy's Avatar
nickrummy
Default RE: Official HPI MT2 Thread
You can not fit a 17t cb with a 52t spur using the stock slots in the chassis. The mesh will be to tight. I'm running a 16t cb and 52 spur with the .18 OS CV-R. It has a bit to much top end for racing but is fun for bashing. If I were to regear I would run a 15t cb and 52 spur.
ORIGINAL: murawskiallen
if you want top end then you should get something like a 17t cb and if you were willing to change the spur gear you could go ro the 47t spur to get even more top end
ORIGINAL: arapoda
no it uses a long spring that you wrap around the clutch shoes, the hpi racing clutch comes with the shoes and the spring
ORIGINAL: arapoda
Does the HPI racing clutch require the same springs that the basic clutch shoes take?
Thanks.
As for racing clutch bells. I have the 13 tooth HPI racing clutch bell. In the next few days I'll be buying a new engine for my MT2 - The LRP z18s. To match the great increase in power I'm looking to get a faster top-end speed. What tooth clutch bell do you guys recommend? (I have the basic 52 tooth spur gear at the moment and am looking to keep that on the car).
