RCU Forums - View Single Post - Rookie II setup tips required.
Old 02-09-2007 | 07:22 PM
siclick33
Default Rookie II setup tips required.
Could anyone give me some tips on the setup of a Rookie II? My first jet was a Kangaroo so I am pretty happy with the basic setup but would like to know what you are doing with your canard/vectoring. I will be using the stock vector pip and P80.
When do you have the canard/vectoring working?
Do you use them both simultaneously or individually switched?
Are they just on or off or do you use different throws at different flight phases?
On or off for take off and landing?
Is it possible/easy to stall the canard? (I am concerned about a sudden nose drop on approach if too much canard is used)
