RCU Forums - View Single Post - Echo 2400 Short blocks SB-1034
Old 02-10-2007 | 07:23 AM
  #228
oldtimer2
My Feedback: (19)
Default RE: Echo 2400T Short blocks
captjohn,
Very nice work on your hub. I already have the hub and prop washer/nut from Roy Sholl for my eng. set up for glow/gas. All I need for the other eng. is the prop adapter, washer to butt up aginst the flywheel, with the L/H threads that I can run as a stright ignition. No taper required. Any way you are doing some good R&D work there plus getting some good practice using your new equipment. Keep up the good work. I see you are still in the deep freeze up there. We are still in the 30 to 40 range here.
Later George
