RE: Gas engine starting
They make really large starters for gassers. A standard starter for glow engines up to .60 will not work, but look around and you will find several "large" options. 32 cc is not that much bigger than the big glow engines (32 cc is about 2 cubic inches). I have a dynatron starter, for example that would spin the 35 cc engine, especially on 24 volts. some of the larger starters can be used with 12 or 24 volts. There is one called the "persuader", too.
