RCU Forums - View Single Post - Echo 2400 Short blocks SB-1034
Old 02-10-2007 | 03:14 PM
  #237
av8tor1977's Avatar
av8tor1977
Default RE: Echo 2400T Short blocks
Wasn't addressed to me, but I still think the ideal fix is to bore a pilot hole in the crank, then cut off the left hand threads, then bore and tap the crank for a right hand thread grade 8 stud. It's a lot less work than the two piece prop hub as well...
AV8TOR
