Barrick,
Here's one site that has Pitch Gauges and Blade balancers.
http://www.helihobby.com/html/blade_tools.html
As far as tools go, for the CP, just some jewelers phillips head screw drivers and .5mm hex allen wrench. The CP package will come with the phillips head screw driver and one .5mm allen wrench.. However, when you come to a point to change blade grips, you need two .5mm allen wrenches.
You can go to google.com and find anything you need. Also, you may want to find some hobby shops in your area that supports the CP.
Dave / Choppersrule
ORIGINAL: Barrrick
thanks so much for the welcoming mat. it will probably work for me. Would somebody be so kind to tell me where to find PITCH GAUGES, BLADE BALANCERS, TOOLS to fit these MICRO SIZE HELICOPTERS. So far I have only seen the SIX PIECE set offered in HorizonHobby for these small helis. ? In point of fact : do these SMALL items exist, or do you ADAPT the regular sizes ? one of the VIDEOS actually shows a PITCH GAUGE being used , even if it was oversized. Just asking !
