RCU Forums - View Single Post - Echo 2400 Short blocks SB-1034
Old 02-10-2007 | 08:20 PM
  #242
captinjohn
Default RE: Echo 2400T Short blocks
av8tor: I know there is a center in the end of crank already. If you use that center you will have drill .625 or 5/8 of a inch further. The further you drill the more chance of getting off center. May be best to cut off threads grind flat and use a new precision center drill which I have 2 of. Maybe a #21 pilot drill like RCIGN1 recomended. I do not know if fine threads would be best or coarse threads? You never did say what you are going to do about the taper? Capt,n
