RCU Forums - View Single Post - Phoenix Sonic .25
Old 02-11-2007 | 12:35 AM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Phoenix Sonic .25
The canard is an original from the fertile mind of Carl "Flaps" Laffert with an occasional sanity check from me. That's his 9th canard and our 22nd twin.
Ugo and I fly together every weekend. He and Flaps are my two flying buds. Flaps is 85 so I drive him out every weekend. He has quit flying and now just builds.
But we have strayed away from the nice flying little Sonic. I have a thread started over in the Twin Forum on the twin fuselage modification. Prograss has been slow as my column is due to be mailed on the 15th and I am working on it. I have already removed the old, 1"-1 1/4" ailerons and have 2" aileron stock and 3/8" tri-stock for wider ailerons. They'll end up being about 2 1/4" wide and should (1) increase the roll rate and (2) lower the wing loading slightly. They add 50 sq in or so.
Flaps will build the new center section with a long dihedral brace. We'll also add a center flap for crow and a landing flap, if needed. I also plan a wider rudder, maybe up to 4" in width. I think the elevator is OK as is.
ID:	618323   Click image for larger version
ID:	618324   Click image for larger version
