RCU Forums - View Single Post - multiplex funjet
Old 02-11-2007 | 02:02 AM
GaryB-RCU's Avatar
GaryB-RCU
Default RE: multiplex funjet
...i'll second that! - truly a sweet flying little "jet"!...100mph plus!...
...i carefully took a dremel & cut a deeper & wider slot in the motor mount screws...so i could use a larger screw driver and not strip them out...got them to work ok...
...i replaced the flaperon linkages with larger gauge music wire - too much flex in those included in the kit - also, i added magnets to hold the canopy down - the plastic hold-downs are questionable...
