ORIGINAL: exeter_acres
also, for safety sake, I might suggest you take your readings from behind the prop instead of in front
Absolutely, you should always work from behind the spinning prop. If the prop should come off, or the plane slip forward, or any number of other things you could be seriously injured by the spinning prop.
Ken
