RCU Forums - View Single Post - Evolution engine backfires
Old 02-11-2007 | 01:09 PM
Hossfly's Avatar
Hossfly
Default RE: Evolution engine backfires
ORIGINAL: evilhorse
i have an evolution .40 in my alpha trainer,after-run oiled it in november, went to start it today and all she does is backfire, so hard that it stripped my spinner backplate. maybe i should just use an electric starter for the first few run ups, cuz it hand started fine last year.
Most likely the oil, however if you are in Jersy, and out in the cold, along with trying to handstart, I suggest you are over-choking and creating a flooded condition.
Here's a trick that we used when I lived in the Chicago-land area and we were out ski-flying in the winter.
Take a small bottle, fill with half glow fuel and half GASOLINE. Prime with that mixture and start normally. Engine started down to 20* (my personal lower limit) just like on a nice 85* day. Gasoline's flash point ( the lowest temperature at which vapors above a volatile combustible substance ignite in air when exposed to flame ) is much lower than methanol.
That will also help clear that congealed after-run oil which clogs up everything. Even here in the humid South East TX area I never -now- use that stuff. Use a good fuel with at least some castor in the fuel, and a few squrits of light anti-rust oil every so often and your engines can be thrown in a box, then start right up after several years. Another myth of RC-- After-run oil!
