RE: aeroace mods
looks like adding some of these diagrams would've been helpfull to start off with. next time i update the page-o-links, i'll add them.
for now though, here's a pic showing where the antenna is soldered to. this usually requires removing the RX from the grey plastic base, there's two little screws holding the RX to the plastic. if you've got a fine tip on your soldering iron, you might be able to solder the wire back on without having to remove the RX from the plastic.
if the antenna wire broke in half in the tail boom, you'll want to make sure you either solder the antenna back together, or put a new one on. otherwise the range will be decreased.
nick
