Problems installing a RCATS-100 electrionic ignition switch.
I just finished installing a RC 100 electronic switch in my model using my Futaba 8UAF system, but on checking my installation I am getting no power going to the ignition.
The RC 100 connector is plugged into Ch.5 ( gear up ) on the Rx and the other two wire leads are spliced into the positive lead after the manual on/ off switch going to the ignition. Checking my install with my voltmeter with the manual switch in the on position and the radio system turned on I get a - 0.000 on my voltmmeter. What have I done wrong.
Karol
