RCU Forums - View Single Post - Problems installing a RCATS-100 electrionic ignition switch.
Old 02-11-2007 | 08:41 PM
Jake Ruddy's Avatar
Jake Ruddy
My Feedback: (40)
Default RE: Problems installing a RCATS-100 electrionic ignition switch.
Did you plug it into an el. channel yet with high rates and move the stick both ways? At max deflection the system should come on if your wiring is correct... if not its either wiring or a faulty unit.
