Twist 60 ?
I just finishewd this plane, I bought a new DX 7 Radio the control horns seem not to give the the ailerons enough throw. I was thinking are there any of you that used after market control horns for the this plane. None of stock arms look like the ones in the instruction booklet. I had to cut the plastic arms because they were bending the pushrod. I also had problems getting ailerons centered because i was turning rod to much. Is very smart to use pushrod connectors on flight surfaces. I've used them on my park flyers and had no problems. The only reason is that I had mental breakdown and tested my patience on getting the aileron centered but after the first one everything else worked out fine just the thick wing kept missing me up. I really think this is going to be fun plane. I'm powering it with a eflite 60 motor. I also may try the eflite 110 motor. I read the review in sport flyer magazine about funtana x with the 110 motor thought that might be cool Thanks.
