RCU Forums - View Single Post - Avicraft Panic
Old 02-12-2007 | 09:18 AM
BaldEagel's Avatar
BaldEagel
Default RE: Avicraft Panic
Eric
I uncoupled the flapperons at the Tx this week end and it inproved the prop hanging measurably, the flapperons where also decreasing the amount of movement of the ailerons as the roll rate is now much inproved also, had to put a bit more expo in to calm it down a bit around centre stick, my ailerons are all working together i.e. four ailerons and four flapperons, I may change this to allow flapperons on the top wing only and ailerons on the bottom just to see what happens. Don't you just love computer radio's? I can play all day with different function mixing.
Mike
