RCU Forums - View Single Post - problem- too much down trim required
Old 02-09-2003 | 07:09 PM
Rodney
Default problem- too much down trim required
Your problem could also be caused by an improper thrust line. If you have to change trim every time you change throttle setting, you may have to much upthrust. If, when you rebuilt the crash, you miss aligned the firewall, this could be the problem.
