RE: OS 55AX carb problem
That is for sure the problem.
It lacks muffler pressure, 8 inch is pretty far with a pitts muffler. Use wider tubing and if that doesn't help you can try to close the muffler exit holes a bit, try an other brand pitts muffler or use a Cline regulator.
