The Stabilizer Of A Plane
Hey Jimcasey. I noticed that you mentioned that glo power could be a problem because of weight shift as fuel is burned. I'm building my B-2 with the fuel tank directly on the c/g and the center of the fuselage. Do you think this is enough to calm down fuel burn weight shift? Do you think having fuel sloshing around in a 10 oz tank could be a problem?
