RE: Winter break in/Tuning and running
Yeah the engine supposed to get around those temps. In the winter the engine doesnt get up to those temps. You could try wrapping the heat sink or part of the ehat simk with tim foil. This will help bring up the temp of the engine. But fif you do this I would get a hand held temp gauge just to be safe. Cause if you wrap to much the heat will accumulate and be to hot and if you dont have enough it will not get warm enough. If you decide to break it in just be careful and check your temps.
