RCU Forums - View Single Post - Gas engine starting
Old 02-13-2007 | 04:35 AM
The Raven's Avatar
The Raven
Default RE: Gas engine starting
ORIGINAL: FoeFoe
Can anyone advise me if it is possible to start a Gas engine with a starter? The engine in question is a 32 cc gas engine the Fuji Imvac BT35 Magneto ignition. Or does it have to be hand started???
I converted a Homelite 25cc and could start it with my normal electric start. It actually cranked it over rather easily.
Later I used a converted Homelite 30cc and the starter could barely pop it over TDC. I eventually bought a helo sized started than another club member was using on his DZY 48cc engine. It's far better but still struggles with that first pass over TDC.....which could be attributable to the 3 year old 7A SLA battery I use.
BTW if you have a magneto engine, you need to spin the engine at a decent speed to get that ignition firing. You'll notice all the 'hand prop' starts are with electronic ignition equipped engines.
