RCU Forums - View Single Post - compatiable 2.2 wheel list
Old 02-13-2007 | 10:48 AM
rclynx's Avatar
rclynx
Default RE: compatiable 2.2 wheel list
All the wheels above will fit only because of the axle diameter and the drive cog is 12mm hex. However many of those wheels will not allow you to proprely install a lock nut on the axle shaft. You guys who have the STX and others who want to put the tires on the Tsunami have to be vary selective. On many wheels with the STX and Tsunami you are SOL unless you want to change your suspension over to the ball type. The problem is when you stick your wheel on the shaft and hex you can't get the nut on because the axle shaft is to short. Its best to go to your LHS and ask them if your could try before your buy. You guys that have the axle held in with the aluminum hex drive can shave the ends of the hex to allow the axle to go threw but make sure the grub locks both still work. One lock works but it comes loose quicker and if you shave to much the wheel hits the hub and locks up. Just don't want any of you guys getting stuck with $15.00 to $50.00 worth of rims you have to try and sell because they didn't fit
