RCU Forums - View Single Post - Building from scratch - need help please.
Old 02-08-2003 | 01:39 AM
kouger-RCU
Default Building from scratch - need help please.
I need help.
I am attempting to build my first plane from scratch. Actually an electric thermal glider. I have the airfoil that I want to use - RG15 - and have done research on how to cut the foam wings. I built and tested the foam cutter – works great. Will use balsa to sheet the wing.
I am going to make the wing 110” from tip to tip.
My problem is the body. I am not sure what length to make the body. I also would like to make the body out of fiberglass but again not sure how to do this. Balsa and plywood is always an option for the body but ideally I would like to make it out of fiberglass.
If you have any ideas on what length/thickness the body should be, or how to make it, please e-mail me at:
[email protected]
I would appreciate any information that one has to offer.
Thank you
