RCU Forums - View Single Post - compatiable 2.2 wheel list
Old 02-13-2007 | 01:32 PM
ehroof
Default RE: compatiable 2.2 wheel list
this is the tsunami with rustler rims, i had to remove some plastic from the back of the rims but you dont notice it that much, rclynx is right, the arms are different on the stx compared to the ball joint suspensions. The tsunami and volcano use the same lower arms so they will work on the volcano too. The jato rims are offset more and will work. The only thing i dont like about the jato rims is that you choice of tires and tire companies is limited, you have alot of choices with the rustler rims.
