RE: Velocity stack design
Many velocity stacks are square on the end (no slant). When they are slanted, best results are usually obtained with the high end of the slant forward (you do not want ram air into the stack or you will have a difficult time maintaining proper mixture at all throttle settings). And yes, a properly designed velocity stack will usually give a slight improvement in performance.
