ORIGINAL: pilot tw
Hello, Joe
the wings for Dragon will be balsa sheet cover the fiberglass then Monocote,
If you want to external painted that you should be order the ARC Kit,
Best Regards
Anton
Anton, can you clarify, will the wing be glassed on the inside or out side surface?
And what will the cost of the complete kit including the retracts wheels brakes, tanks, pipe and all the other normal stuff you supply with the other kits?
Jason
