RCU Forums - View Single Post - Jet Vhull
Thread: Jet Vhull
Old 02-13-2007 | 04:58 PM
Gyrotech
Default RE: Jet Vhull
Well looks like I'll be hitting up ebay tonight. Need a lipo balancer too
BTW, I worked on my variable nozzle today, I've got to go to work, but it's all mocked up and ready to solder..
Don't forget to post pictures
Specs:
Requires:
20A to 35A Brushless ESC
10x6 to 12x6 Prop
7.4V or 11.1V Li-Po or 6-10 cell Ni-Mh/Ni-CD
Features:
High Torque, direct drive alternative to inrunner brushless motors
Includes mount, prop adapter, and mounting hardware
4mm shaft can easily be reversed for alternative motor installation
High quality construction with ball bearings and hardened steel shaft
Slotted 12-pole outrunner design
Specifications:
Type: brushless
Bearings or Bushings: Bearings
Wire Gauge: 16
Recommended Prop Range: 10x7 to 12x6
RPM/Volt (Kv): 910 (RPM per volt)
Resistance (Ri): 0.08 Ohms
Idle Current (Io): 0.85 @ 8V
Shaft Diameter: 4mm (0.16 in)
Weight: 3.1 oz (87g)
Diameter: 1.4 in (35mm)
Lenght: 1.3 in (33mm)
Continuous Current: 20A
Maximum Burst Current: 25A for 15 seconds
Cells: 6-10 NiCd/NiMh or 2- to 3-cell LiPo
Speed Control: 20A to 35A Brushless
One more time,: 910 rmp-per-volt x 11.1v's which is my 3 cell lipo pack = 10'101rpm
Seeing how I want optimum rpm (18'000 ish) Lets go, 18'000rpm / 11.1volts = 1621 kv
So I need something around 1600kv Any suggestions for what motor to get? I should add I have a Eflite 40 amp ESC
Does that sound right to you guys?
