RCU Forums - View Single Post - evolution .46 still cutting out
Old 02-14-2007 | 11:32 AM
  #49
bkdavy's Avatar
bkdavy
Default RE: evolution .46 still cutting out
The blue collar is attached to the low speed mixture adjustment. Turning it clockwise will richen the low speed mix. Turning counter clockwise will lean the low speed mix. The pin sticking out of the collar is the limiter to prevent the user from turning it past a certain point. Therefore, removing the pin will allow you to make a broader range of adjustments to the low end.
Brad
