RCU Forums - View Single Post - Zeque Build Glow Powered...
Old 02-14-2007 | 05:21 PM
  #104
rgreen24's Avatar
rgreen24
Default RE: Zeque Build Glow Powered...
Hey Rusty I am also using the MK remote start for my Genisis. I removed the blue housing, and the heat shrink, applied JB weld to the connection and the added another heat shrink tube to the connector. Then I also added a 1/16 inch piece of medium fuel tubing over the tip of the glow plug, that way once you push down the tip, it will be somewhat soft mounted and should hopefully last longer. By the way I got this information from a thread on RCU a while back, so it is not my info, but figured I should pass it along. See you tommorrow.
