RCU Forums - View Single Post - 4 stroke??
Thread: 4 stroke??
Old 02-10-2003 | 05:01 AM
lownslo's Avatar
lownslo
Default syringe for oil...
Hello handysmurf, Here is a thread about after run oil, and I had post #7 on it.........
http://rcuniverse.com/showthread.php...hlight=lownslo
I might add that since that post I have been using a syringe with 1/8" brass tube on the end, and use it the same as the eye dropper. ALSO..... I saw somewhere, (?), to minimize the length of that tubing from the breather nipple. Something to do with restricting the air flow from the crankcase. I just made mine a short as possible, and still be able to insert the syringe/oil at the bottom of my Spacewalker cowl. I also have a .91 Saito in it. I will read your starting problems again and see if I can help.... lownslo
