ORIGINAL: spiftacu1ar
Hey, Azzman, could you tell me the dimesions of those tanks (so i can plan out my mod). THanx, Sutyen
Okay bro, here goes:
Total height (to highest point on lid) 78mm
Length 73mm plus 10mm for each of the mounts (93mm total)
Width 40mm plus 2mm each side for seam, (44mm total)
ORIGINAL: Trex808
First off, that is an excellent setup! Good job! Really clean. Secondly, how much more length did you have to add to your tvp's to fit everything in? I'm trying to get Chronic to build a set of his extended lcg tvp's.....if he get's back to me? And I'd like to try a setup similar to yours. Can you post some specs? Thanks.
I managed to extend the front 10mm (using rear driveshaft) and the rear 3mm, for a total of 13mm stretch. I just make sure I use o-rings at the end of each driveshaft to keep them centered because there is a little more play than before.
You will be safe with a 8mm stretch up front (if using chronics TVP's) to fit the tanks AND the battery box in there.
Also I finished the skidplate, like the TVP's its 3mm aluminum, held there with...you guessed it some more engine plate braces.
